Reset flow related to RITM
03-18-2025 11:25 PM - edited 03-18-2025 11:30 PM
Hello mates,
i want to share this scenario which is working fine form me, if you have related query it would be helpful,
i have created a UI action to reset the flow related to RITM and approvals.
function checkOpen() {
var userConfirmation = confirm('Do you want to Reopen this RITM again?');
if (userConfirmation) {
gsftSubmit(null, g_form.getFormElement(), 'reopen_ritm');
if (typeof window == 'undefined') {
restartFlow();
function restartFlow() {
try {
// Reopen and update the parent request (REQ)
var reqRecord = new GlideRecord('sc_request');
if (reqRecord.get(current.request)) {
reqRecord.setWorkflow(false); // Prevent workflow triggers on update
reqRecord.request_state = 'requested'; // Set REQ to 'requested'
reqRecord.active = true;
reqRecord.update();
gs.info('Parent REQ reopened: ' + reqRecord.number);
// Restart traditional workflow for REQ
var wflow = new Workflow();
wflow.restartWorkflow(reqRecord);
wflow.runFlows(reqRecord, "update");
throw new Error('Unable to find parent request (REQ) for RITM: ' + current.number);
// Cancel all related approvals
var approvals = new GlideRecord('sysapproval_approver');
approvals.addQuery('sysapproval', current.sys_id.toString());
approvals.orderByDesc('sys_created_on');
approvals.query();
while (approvals.next()) {
approvals.state = 'cancelled';
approvals.update();
gs.info('Approval cancelled: ' + approvals.sys_id);
// Cancel existing flow contexts for the RITM
var grFlowContext = new GlideRecord('sys_flow_context');
grFlowContext.addQuery('source_record', current.sys_id.toString());
grFlowContext.orderByDesc('sys_created_on');
grFlowContext.query();
while (grFlowContext.next()) {
sn_fd.FlowAPI.cancel(grFlowContext.sys_id.toString(), 'cancel');
gs.info('Flow context cancelled: ' + grFlowContext.sys_id);
//Restart the Flow Designer flow for the RITM
var flow = current.cat_item.flow_designer_flow;
if (!flow) throw new Error('Flow Designer flow not found for RITM: ' + current.number);
var flowName = flow.sys_scope.scope + "." + flow.internal_name;
var inputs = { 'table_name': 'sc_req_item', 'request_item': current };
var contextId = sn_fd.FlowAPI.startFlow(flowName, inputs);
//Update RITM state and fields
current.state = '1'; // Set to 'Open'
current.active = true;
current.setValue('flow_context', contextId);
current.work_notes = 'Request restarted by ' + gs.getUserDisplayName();
current.update();
gs.info('RITM restarted: ' + current.number + ' with new Flow Context: ' + contextId);
//Redirect to the RITM record
} catch (ex) {
gs.error('Error in restartFlow: ' + ex.message);
check client and use (checkOpen()) in Onclick & put (reopen_ritm) in Action name.
If it helps mark as helpfull.
03-18-2025 11:59 PM
So you wanted to share your code which will be helpful for other members?
03-19-2025 12:10 AM
@Ankur Bawiskar yes just wanted to share code so it will helpful someone.
