catalog item is not opening from portal
ā07-08-2024 05:48 AM
hi All
one of catalog item is not opening from portal , remaining are opening
what could be the reason behind it ?
ā07-08-2024 05:58 AM
Hi @pramn
Agree with Anurag, any error ? available for selection? any user crieteria? Any screenshot?
ā07-08-2024 06:55 AM
ā07-08-2024 06:03 AM
Hi @pramn
Can you check whether its set to active or inactive. Also, would be great if you share some snapshots if its active and still not opening from portal.
If this solution resolves your query, kindly mark it as the accepted solution and give it a thumbs up.
Best Regards,
Krushna Birla
ā03-11-2025 10:28 AM
i am having the same issues, the ci is in published state.
ā03-11-2025 10:56 AM
s i have onload to suppress the Order Button and a script to active the submit button
