Catalog Task creation in Subflow in Flow designer
Naren7
i want to create above 60 actions in flow designer , as per the OOB actions limit in flow designer is 50 only.
i  stucked at creation of subflow to create  50 catalog taks in the subflow.
How to create the  tasks in subflow ??
can any one help me out
Thank you
Hi Naren,
If your query is resolved, can you please mark my answer as correct and close this thread for others.
If you have a follow up question or a query do let me know.
Shloke
Hello, how do you enter the Catalog Item so that Catalog variables are available to the Catalog Task? I cannot use a data pill on that control.
yes you can create catalog task in subflow
check these links which should help you get started
Create a subflow
there is a good video from Chuck as well
Lessons Learned - Flow Designer Subflows
