Catalog UI Policy not working as required (Explained in Description)
rishabh31
Respected Community,
When Selecting 'Task' (Choice) in Variable Field- Job Responsibilities, then only a Variable field- 'Task entry' becomes Mandatory & Visible.
*Outcome (Achieved but with Gap below)-
When Selecting 'Duties' (Choice) in Variable Field- Job Responsibilities, then only a Variable field- 'Duties entry' becomes Mandatory & Visible.
*Outcome (Achieved but with Gap)-
When Selecting 'Responsibilities' (Choice) in Variable Field- Job Responsibilities, then only a Variable field- 'Responsibilties entry' becomes Mandatory & Visible.
& When Selecting 'All' (Choice) in Variable Field- Job Responsibilities, then all three Variable fields- 'Task entry', 'Duties entry' & 'Responsibilties entry' becomes Mandatory & Visible.
*Outcome (Not Achieved as Duties Entry Missing, Sometimes its Visible & many times NOT)-
I tried to achieve this by UI Actions OR UI Scripts also, but not getting results, please help me with revise script or process, I will be thankful!
Thanks in advance
OR else I believe you can achieve this using UI policy actions as well with below conditions in UI policy. you can create 3 UI Policies with details mentioned below:
Keep
On load : checked (on all UI Policies)
Reverse if false : checked (on all UI Policies)
1. UI policy for Task:
Condition - Job Responsibilities IS Task OR ALL
In UI policy actions - Task entry :  mandatory - true, visible - true
2. UI policy for Duties:
Condition - Job Responsibilities IS Duties OR ALL
In UI policy actions - Duties entry: mandatory - true, visible - true
3. UI policy for Responsibilities:
Condition - Job Responsibilities IS Responsibilities OR ALL
In UI policy actions - Responsibilities entry: mandatory - true, visible - true
Please mark my respsone as helpful/correct, if it answer your question.
@Mahendra  Sir, Thanks but Coding is Not working for any of field, can you please help me with below code (I modified field value & name), please help with this
*Execute if True-
function onCondition() {
var jobResponsibility = g_form.getValue("job_responsibilities");
if (jobResponsibilty == '4') { // Value for Choice 'All' is 4
g_form.setDisplay("task_entry", true);
g_form.setDisplay("duties_entry", true);
g_form.setDisplay("responsibilities_entry", true);
g_form.setMandatory("task_entry", true);
g_form.setMandatory("duties_entry", true);
g_form.setMandatory("responsibilities_entry", true);
} else if (jobResponsibility == '1') { // Value for Choice 'Task' is 1
// While hiding the fields you first need to set Mandatory as false and then set Display as false;
g_form.setMandatory("duties_entry", false);
g_form.setMandatory("responsibilities_entry", false);
g_form.setDisplay("duties_entry", false);
g_form.setDisplay("responsibilities_entry", false);
} else if (jobResponsibility == '3') { // Value for Choice 'Duties' is 3
g_form.setMandatory("task_entry", false);
g_form.setDisplay("task_entry", false);
} else if (jobResponsibility == '2') { // Value for Choice 'Responsibilities' is 2
*Execute if False-
Sagar Pagar
I would suggest to add UI policy actions instead of scripts in UI policy. disable the existing UI polices you have written.
You have to write 3 UI policies for this as follows:
UI policy 1:
UI policy action - Task entry :  mandatory - true, visible - true
UI policy 2:
UI policy action - Duties entry: mandatory - true, visible - true
UI policy 3:
UI policy action - Responsibilities entry: mandatory - true, visible - true
Try this as let me know the results!
Sagar Pagar
Nikita Kale
Giga Guru
Hi Rishabh
Create 3 UI Policies as below:
UI Policy 1
UI Policy 2
UI Policy 3
Please mark the response as helpful/correct, if it answers your question.
Nikita
