Catalog variable for multi select
‎03-27-2017 04:06 PM
I have a requirement to let a user select multiple choices from a drop down list. See below
How do I accomplish this? Can't find an OOB option for variable type that let's me do the above.
Service Catalog
- 28,217 Views
‎03-27-2017 09:40 PM
You can use the Variable as "List Collector" for selecting multiple Values as shown below:
The above List Collector can also be converted into a Glide List Variable as it is available in Incident or any other form, similar to Watch List field where users can select multiple values too .The only modification needed to the above Variable is while defining the variable give the Variable attributes as "glide_list" as shown below:
Result:
User can select Multiple Values here from the table you are referencing to:)
Hope this helps.Mark the answer as correct/helpful based on impact.
Shloke
Shloke
‎06-08-2018 11:32 AM
Hi Shloke,
I have a small question in this. Is it possible to place these value on different fields once we select multiple options from referenced table?
We have a requirement wherein we want to select multiple options from referenced table and place each option in different field. Is this possible with glide_list option?
‎03-30-2017 12:10 PM
Did you got a chance to Test the Solution provided for your query.
If your query is Resolved, Please mark the answer as correct so that the thread can be removed from the Unanswered list.
Shloke
Shloke
‎06-15-2017 06:45 PM
Shloke,
I had the same question and tried your suggestion. It totally worked for me. Thanks!
‎06-15-2017 06:59 PM
Shloke,
Actually, I have a follow-up question on this. I followed your suggestion and it worked in Istanbul but it didn't work in Geneva. Does "glide_list" not supported in Geneva?
Jennifer
