08-12-2026 06:54 AM
Summary: Even though Change and Problem Management Plugins are enabled, we are unable to use Change & Problem Management Features
Symptoms:
- We do not see change and problem navigation menus in Navigation filter
- We do not see problem_id, caused_by, rfc fields on Incident form (these fields are available in Zurich under Related Records tab)
- We do not see option to create problem and change from SOW
- This is a predominant issue reported in communities as well for Australia release.
- If you upgrade from Zurich or Yokohoma release (as examples) , you wont face this issue. According to our assessment, this issue is observed within Freshly Acquired instances/PDI
Solution:
- You must install "Service Operations Workspace ITSM Advanced Applications" application to resolve the issue (App ID: sn_sow_itsm_adv_ct )
- Advanced ITSM capabilities such as Change Management, Problem Management, On-Call Scheduling, Walk-Up Experience, and Major Incident Management are not installed out of the box on new instances. To enable these features, the Service Operations Workspace ITSM Advanced Applications package must be installed. This package is available as a Store application.
Hope it helps the community.
- 2,421 Views
08-25-2026 11:00 PM
@Dr Atul - LNG Thanks - the article was with a solution as well. I couldn't post it as a blog so posted it as a question to help the community.
Solution:
10-08-2026 05:46 AM
thanks it seemst o work now. they have removed the calendar component dependency it seems now to allow the installation.
10-20-2026 02:07 AM
This appears to be broken again. You cannot install Service Operations Workspace ITSM Advanced Applications as it is now dependent on the Calendar component which is not available on the developer instance. Are there other fixes?
10-20-2026 02:17 AM
Installing version 9.1.1 works but the latest version cannot be installed at the moment.
3 weeks ago
Any suggestion for getting this in a PDI? The Application install keeps failing.
