Change Management Workflow is Skipping CAB Approval
peekay19
I want the change request to go for a CAB approval after the Requester's manager approves it, however, I'm having three issues.
1. It's skipping the CAB approval
2. The state should change to Implementation, but it is changing to Waiting for Approval
3. It is creating the implementation task without CAB
20 REPLIES 20
peekay19
It is a state field.
On Mon, Oct 2, 2017 at 12:41 PM, pavank <community-no-reply@servicenow.com>
pavank
You need to set state field in the workflow to whatever state it needs to be moved after CAB Approval.
peekay19
That is what I did here..
On Mon, Oct 2, 2017 at 2:43 PM, pavank <community-no-reply@servicenow.com>
pavank
Approval Action will not set the State field. It will set the Approval field. You need to set State field using Set Values workflow activity.
peekay19
Thank you. It's now working as expected.
