change management
sriramsin
Hi guys ,
I deactivated the OOTB change flow , how can reactivate it ?
yashkamde
Tera Sage
Hello @sriramsin ,
Navigate to the sys_hub_flow.list table view and attempt to activate the flow directly from there. If activation isn’t available through that interface, the alternative approach would be to clone the flow and then activate the cloned version instead.
Dr Atul - LNG
everyone answered @sriramsin
SohamTipnis
Hi @sriramsin,
You can refer to this article; this will help you in your requirement as well as in the future.
https://www.servicenow.com/community/itsm-forum/change-management-in-servicenow-everything-you-need-...
If you find my answer useful, please mark it as Helpful and Correct â€ŒðŸ˜Š
Soham Tipnis
ServiceNow Developer ||  Technical Consultant
LinkedIn: www.linkedin.com/in/sohamtipnis10
its_SumitNow
Hi @sriramsin
If you've deactivated the OOTB change flow, Then you can't do anything, so the best option is copy that flow and activate it
if my response helped ,kindly mark helpful & Accept as Solution 🙂
Sumit
