checking if a record exists using get()
ServiceNow Use6
I wrote a script where I can check if a record exists with the following condition and it is not able to find.
var methods = new GlideRecord("incident");
var returnValue = methods.get("caller_id", "Bud Richman");
gs.addInfoMessage("the record that is to be returned is available " + returnValue);
It is returning false even though there is  record with the scenario
Suman P.
Mark Roethof
Hi there,
caller_id is a reference, so sys_id. You are searching on a string though. That won't work.
So either search on the sys_id, or use caller_id.name
Kind regards,
Mark
2020, 2021 ServiceNow Community MVP
2020, 2021 ServiceNow Developer MVP
LinkedIn
Community article, blog, video list
Kind regards,
Mark Roethof
10x ServiceNow MVP
LinkedIn
ServiceNow Use6
Got it Ankur. It worked. Thanks Mark.
Suman P.
