CI with multiple IP addresses
Is it possible for a configuration item to have multiple addresses? Would I have to setup a CI for each IP address?
@pritam.sahota - We decided to add a field "IP Addresses" which is a slushbucket pulling from cmdb_ci_ip_address table. This worked for us instead of using related list.
@bookerc - A CI for each IP is a matter of what you want to consider a CI. If you think IP addresses are CI's than yes, but you could consider an IP address an attribute of a CI such as a server or virtual machine. If that is the case than it can be just stored on your CI that has this IP address.
Really a matter of preference.
Thanks for the reply sherman.1206,
I'll investigate that avenue, are you still able to search for the multiple IP's using the slushbucket method i.e. Go to IP Address search?
Pritam
