10-15-2025 11:54 AM
I have create an onChange client script on 'type' field with the logic to display choices in choice field 'suspension_reason'.
var internal1 = g_scratchpad.internalreasons;
var external1 = g_scratchpad.externalreasons;
var type1 = g_form.getValue('type');
internal1 = internal1.split(',');
external1 = external1.split(',');
// Add the appropriate options based on the selected type
if (type1 == 'Internal Suspend') {
g_form.setValue('your_choice_field', '');
for (var j1 = 0; j1 < external1.length; j1++) {
g_form.removeOption('suspension_reason', external1[j1]);
for (var k1 = 0; k1 < internal1.length; k1++) {
g_form.addOption('suspension_reason', internal1[k1]);
} else if (type1 == 'External Suspend') {
for (var l1 = 0; l1 < internal1.length; l1++) {
g_form.removeOption('suspension_reason', internal1[l1]);
for (var m1 = 0; m1 < external1.length; m1++) {
g_form.addOption('suspension_reason', external1[m1]);
g_form.clearValue('suspension_reason');
Here,
When I select type as Internal Suspend, the choices in suspension_reason fields show correctly. But when I change the type from Internal Suspend to External Suspend, the choices show 'None'.
Same happens vice versa, when I select External Suspend, the choices in suspension_reason show properly, but when I reselect the type field as Internal Suspend, the choices show 'None'.
What changes can I make to make it work as expected.
I have tried adding g_form.clearOptions('suspension_reason'); before if/else if conditions doesnt work.
Please drop if you guys have any suggestions to make.
10-16-2025 02:03 AM
try this
-> Remove options one-by-one
-> Explicitly manage the '-- None --' option
10-15-2025 10:14 PM
Hi @Bhojraj Chauhan ,
You're very close, but the issue is due to how you're managing the dynamic options for the suspension_reason field using g_form.removeOption() and g_form.addOption().
When switching between the "Internal Suspend" and "External Suspend" types, you're only removing the options from the other set — not clearing and fully re-adding all expected options cleanly.
You never fully clear all options before adding the new set, leading to stale or missing options.
You’re adding options without specifying a label or value if internal1 or external1 contain objects or values that aren't strings.
g_form.setValue('your_choice_field', '') should be replaced with the actual variable name: 'suspension_reason'.
Updated script:
if (isLoading || newValue === '') return;
var internalList = g_scratchpad.internalreasons || '';
var externalList = g_scratchpad.externalreasons || '';
var type = g_form.getValue('type');
var field = 'suspension_reason';
// Ensure the values are arrays
var internalArray = internalList.split(',');
var externalArray = externalList.split(',');
// Clear all existing options first
g_form.clearOptions(field);
// Add a default/placeholder option
g_form.addOption(field, '', '-- None --');
if (type === 'Internal Suspend') {
for (var i = 0; i < internalArray.length; i++) {
var value = internalArray[i].trim();
g_form.addOption(field, value, value);
} else if (type === 'External Suspend') {
for (var j = 0; j < externalArray.length; j++) {
var value = externalArray[j].trim();
// Always reset the field to blank to avoid selecting old value
g_form.setValue(field, '');
Mark this as helpful and correct, if this helps you.
Yaswanth
10-15-2025 11:07 PM
Hi, thank you for your help
Its not displaying values for the first time using this script. The dropdown is not displaying any choices.
I had corrected this point but no progress too sadly.
10-15-2025 11:32 PM - edited 10-16-2025 12:00 AM
Hello Bhojraj,
In your description, you mention two field names ('type', and 'supension_reason'), and of those two fields the onChange script is triggered based on the 'type' selection. I'm not sure if there is more happening with the 'your_choice_field' from lines 15 and 23, but the g_form.clearValues() on the last line would render the dropdown empty with every selection.
My suggestion would be to use the clearOptions() before the other logic, and remove the loops for removing the options. Something like this...
if (isLoading)
if (newValue === '' || newValue == oldValue)
var reasonList = (newValue == 'Internal Suspend') ? internal1 : external1;
getOptions(reasonList);
function getOptions(list) {
var options = list.split(',');
var len = options.length;
for (var i=0; i<len; i++) {
g_form.addOption('suspension_reason', options[i]);
If my response helped, please mark it as the accepted solution so others can benefit as well.
Coop
10-16-2025 01:04 AM
Hi @Darris Cooper , clearOptions is not working for this form as it is clearing all the choices from the first iteration itself, please suggest some alternative in place of clearOptions() for removing the options and adding in a fresh set. this will fix the script
