Client script to calculate Difference between 2 fields of type duration( not dates) these are hours, minutes and secons)
bammar
Hello All,
I specifically need a client script not a business rule to calculate the difference between 2 fields of type duration
So I have field   planned effort   , actual effort and remaining effort. All are of type duration.   Quite simply if i type Planned effort 10, and Actual 5, I need an on Change scrip that will automatically make Remaining effort 5. If tried many things and couldnt get this to work. Any help would be appreciated. I have seen some proposed solutions that need to use a client script.
Here you go. Create 2 onChnage client scripts and a script include. The following code assumes the u_dur_1, u_du_2,u_dur_3 as the three duration field names.
OnChange script on u_dur_1 field
  if(g_form.getValue('u_dur_2')!=''){
  var ga = new GlideAjax('CalculateDuration');
  ga.addParam('sysparm_name','durationCalulator');
  ga.addParam('sysparm_dur1',newValue);
  ga.addParam('sysparm_dur2',g_form.getValue('u_dur_2'));
  ga.getXML(CallBack);
  function CallBack(response) {
  g_form.setValue('u_dur_3',answer);
OnChange client script on u_dur_2 field:
  if(g_form.getValue('u_dur_1')!=''){
  ga.addParam('sysparm_dur2',newValue);
  ga.addParam('sysparm_dur1',g_form.getValue('u_dur_1'));
Script include:
client callable:true
Script:
var CalculateDuration = Class.create();
CalculateDuration.prototype = Object.extendsObject(AbstractAjaxProcessor, {
  durationCalulator: function(){
  var duration = new GlideDuration(this.getParameter('sysparm_dur1') );
  var duration2 = new GlideDuration(this.getParameter('sysparm_dur2') );
  var answer = duration.subtract(duration2);
  return answer.getDurationValue();
  type: 'CalculateDuration'
Abhinay Erra
All of them are of Duration type right?
Yes i Checked the dictionary now and they all are of type duration
Script include:
Script:
This really did work Perfectly, I appreciate it.
