client script
soniya patil
how to make  short description field  mandatory  in table
Community Alums
Hello @soniya patil,
You can write below code in client script onSubmit condition
Please mark my answer as helpful if it helped in finding solution
Priyanka
manjusha_
@soniya patil
Below are multiple ways to make a field mandatory ,but need to select it based on your requirement
1.Dictionary
2.Ui policy
3.Client script
As a best practice suggested by ServiceNow we should go with ui policies
If you want to make field mandatory on Onload of form or Onchange of  a field you should go with Ui policy
Explain your requirement in detail so i can help you
If my answer solved your issue, please mark my answer as Correct & 👍Helpful based on the Impact
Manjusha Bangale
Ankur Bawiskar
@soniya patil
I could see multiple responses to your question.
But I would like to know what did you try so far and where are you stuck?
Certified Technical Architect  ||  9x ServiceNow MVP  ||  ServiceNow Community Leader
