Color of favourite dialog field
jthomsen
how can I change the color of the dialog field to make a favourite? For some reason it is in white and the letters are not visible.
13 REPLIES 13
Hi @jthomsen
I doubt you can change the color
Well on my instance it is a different color and I don´t know why 😞
Are you on UI 16?
yes
That is case, if you move to Next exp, you will get same.
