Configure Maintenance and Black out Schedule
‎03-21-2021 01:04 PM
ITSM SIMULATOR, HELP!!
Maintenance and blackout schedules should be defined and available in the system so that change requesters understand when a change can be implemented and when they should not be implemented.
1. Create a maintenance schedule named: "Data Center - Maintenance Weekend Schedule".
a) Should be applied to all "Network", "Unix Server", and "Linux Server" CI classes.
b) Create a schedule entry for all day, every Monday (repeating weekly) until the end of the year as part of this schedule.
2. Create a blackout schedule named: "Monthly Freeze/Blackout Period".
a) Should be applied to all CI classes.
b) Create a schedule entry for every 3rd Thursday of each month (repeating monthly), until the end of the year as part of this blackout schedule.
Can someone point out what's wrong here???
- 25,153 Views
‎03-04-2024 06:17 AM - edited ‎03-04-2024 06:18 AM
I'm doing this lab and the answer is:
"Task Result: Failed
Please validate the Data Center - Maintenance Weekend Schedule maintenance schedule was created correctly. Have you included all three classes required?"
And the steps I have taken are the ones I attach in images.
Can someone help me please? 
‎03-04-2024 06:21 AM
Please also attach the Question for this. It might not be the same question.
‎02-27-2025 08:17 PM
Your configuration appears to be correct but it seems you created the maintenance schedule on a blackout schedule menu
‎04-27-2024 12:11 AM
Hint: Validate the Source field is set to the proper value!
‎04-27-2024 12:20 AM
I created blackout schedule under the maintenance schedule. That was the biggest problem.
