Configure Reclassification System properties - CMDB Micro certification
Romesh
Giga Contributor
Please help me out, how to solve this part of cmdb certification as i need to create reclassification tasks first for upgrade, downgrade & switch. Please find the attach and guide me. Thanks in advance!!!
MrMuhammad
You are required to update the highlighted system properties value to false.
Please mark this accepted/helpful, if applicable.
Thanks & Regards,
Sharjeel
Anoop19
1) Type sys_properties.list in left navigator.
2) From the list filter the name field for *glide.class.
3) You will get 3 records and change the value from true to false.
jvazquezfrei
Aishwarya Patil
As the Cloud Dimensions CMDB administrator, you are tasked to reconfigure the 3 reclassification system properties to force the creation of a CI Reclassification task for any CMDB class upgrade, downgrade or switch.
Solution: From the Navigator search for sys_properties.list and you will find properties as follows-
1. glide.class.downgrade.enabled
2. glide.class.switch.enabled
3. glide.class.upgrade.enabled
You have to set the Value field to False to complete this Task in CMDB Cource on Now Learning.
Please check the attached Screenshot,
