Create system property for mapping and use it for dynamic value
Priyanka Chaud1
I want to use a mapping kind of thing
and store this in system property and use it  in my script include to make tablename,parentfield and column name dynamic how can i achieve this @suvro
suvro
Just create a property with below values
{ "task" :{"refField": "parent", "qField" : "number" }, "incident" :{"refField": "parent_incident", "qField" : "number" }, "sys_user" :{"refField": "manager", "qField" : "name" }, "problem" :{"refField": "duplicate_of", "qField" : "number" }}
call that property
var tableName = gs.getProperty('property name'); //another property which stores tablename
var propV = gs.getProperty('property_name');
var propObj = JSON.parse(propV);
Now you can use it :
propObj[tableName ].refField and propObj[tableName ].qField
15 REPLIES 15
suvro
call that property
@suvro i have to use
in every function of script include
Define the variables in the  initialize function of the script include like below then it will be available for all functions of the script include. You will not have to define those in every function
this.tableName =
this.propV =
initialize: function() {
      this.tableName = gs.getProperty('x_cyso_org_hierarc.dropdown_value');
       this.propV = gs.getProperty('x_cyso_org_hierarc.parentref _fields');
is this the way it would be initialiaze in one function @suvro beacuse i used it so got errors in logs
