CSV/Excel Data imports via HTTPS method
Narendra7
Kilo Expert
I have read that we can import https files data into Servicenow from Data source. However, when I try to Load either https/http, I keep on getting Null records. Am I missing something here? Could someone please point me in right direction.find_real_file.png
When I click on Test Load 20 Records and Load All records from Related Links, I am getting Null Records to the Import Set table.
Status showing Loaded, however records are zero.
Why it is behaving like this ?
Narendra
Thanks Mark!! I figured out the problem. The problem is with file retrieval method. It is SFTP method not https method. After I change the retrieval method from https to sftp it worked for me. My initial understanding was wrong. Thanks for your support .
Hmm. The only other thing I can think of is that your https data source is restricting access somehow. I wonder if you could try to access that file with your web browser when you're not connected to the same network as the https server?
I am able to access that https webserver from Public network.
Do you think from ServiceNow do we need to enable any PORT ? if Yes, to whom I need to contact.
Narendra
I wouldn't think so for https. Either way you might be best off contacting customer support at this point. Please let me know what you find.
Sure, thanks Mark for your support and suggestions.
Narendra
This may not help either, but I noticed a similar issue here...with a possible fix from John Andersen.
https://community.servicenow.com/community?id=community_question&sys_id=a48e4b21dbdcdbc01dcaf3231f961911
