custom application
tushar_ghadage
Hi all ,
I have custom application called leave management developed on my pdi using studio for my learning
but how do it move it let's say to my 2nd pdi
can anyone guide as I am currently learning custom application development.
thanks
6 ACCEPTED SOLUTIONS
Bhuvan
Giga Patron
@tushar_ghadage
Go to custom application in studio -> Update set -> Create a new update set.
Go to custom application in studio -> Deployment and open the application and select App Settings and related links [wheel cog] -> Publish to update set
Export and import the update set in your second PDI.
If this helped to answer your query, please mark it helpful & accept the solution.
Bhuvan
Ankur Bawiskar
@tushar_ghadage
yes it's possible to migrate custom app from 1 PDI to another.
1) Publish the app to update set, this update set you can export and then import in other PDI in retrieved Update set
Detailed steps here
Publish an application to an Update Set
@tushar_ghadage
When you open that application record, you see Related link "Publish to Update Set"
When you use that all your application files for that scoped app are pushed to update set and 1 single large update set is created.
You can export that as XML and then in target instance go to retrieved update set and import this XML, preview and commit.
You can move a custom app via an Update Set. I did the same in my PDI and moved it to another PDI later.
When you start building the custom app, an Update Set is created automatically. You can then complete the app development and move the Update Set to the next instance.
Hi @tushar_ghadage ,
Check this:-
https://support.servicenow.com/kb?id=kb_article_view&sysparm_article=KB0961293
Nikhil Bajaj
Please appreciate my efforts, help and support extended to you by clicking on – “Accept as Solution”; button under my answer. It will motivate me to help others as well.
Nikhil Bajaj
ServiceNow Rising Star-2025
@tushar_ghadage
Did you get a chance to review this ?
I believe using my response, you should be able to migrate the custom application via update sets. If my response helped to answer your query, please mark it helpful & accept the solution.
Bhuvan
11 REPLIES 11
Hi @tushar_ghadage
Is anything wrong with my answers?
Check this:-
Nikhil Bajaj
Nikhil Bajaj
Nikhil Bajaj9
Tera Sage
Please check the thread for details:-
https://www.servicenow.com/community/developer-forum/how-to-move-scoped-app-from-one-one-instance-to...
If my answer helped you, please mark it- solution accepted.
Nikhil Bajaj
Nikhil Bajaj
Bhuvan
Giga Patron
@tushar_ghadage
Bhuvan
@tushar_ghadage
Bhuvan
