custom script action in flow designer is not working
I have created custom action in the flow designer we are passing input(password)  in the custom action but we are not getting the plain text password
chandan2212_0-1753258507263.pngchandan2212_1-1753258558706.pngchandan2212_2-1753258576326.pngchandan2212_3-1753258594718.png
we are getting the password2 output while running the test connection but we are not getting the plain text .
Can you help on this .
Thanks and Regards,
Chandan Patra
@Community Alums
from where this action is getting called?
I got the point that you want to send encrypted password to AD server may be via some spoke etc
For GlideEncrypter's encrypt method you need to pass plain text password and then it will give you encrypted value.
GlideEncrypter - encrypt(String clearString)
@Community Alums
are you getting null in the output variable?
Since you are passing mask type input to the input variable and hence it might not be able to print that
HI @Ankur Bawiskar
Can you please advise me how to write the script so that it will print the output whatever i gave input.
@Community Alums
I will have to check in my instance when I get time.
But is your functionality not working as expected?
Why you are insisting on printing that value?
if your functionality is working as expected then you need not worry
