Data lookup definition not working onchange
Kiranmai_KVL
There is a requirement to set a field based on data definition lookup (similar to priority) but as below
Based on A & B , derive C.
Based on X & Y, derive Z.
And based on C & Z, set the final value in field K.
We created on lookup rules for all the combinations. However  when changing the values of A& B / X & Y, values C & Z is not deriving as expected.. This is affecting the final value in field K. However this issue is intermittent.
Deepak Kumar1
try running this code in global scope in the background script -
gs.invalidateCache();
And check the form changes again.. This will fix the issue
