Difference between Catalog item and record producer.
AnandKumar1
Hi Team,
I would like to understand the dfference between Catalog item and record producer. And advantages,
thanks,
Anand Kumar.
AbhishekGardade
Tera Sage
Hello Anand,
1. Catalog Item will end up in opening a request and reqeust item and attaches a workflow and catalog task, approvals Where as a Record producer simply insert a record in the selected table.
2. With catalog item, You can add multiple items to cart and generate request and multiple RITM's. where as a record producer it only creates a single record on target table
3. Primarily, the difference is which type of record is created upon submission. I would use a catalog item when you want to generate a request, complete with a workflow, approvals, tasks, etc, and a record producer when you want to gather some information using a form (variables) but create some other type of record (incident, change, enhancement, etc.) as a result.
4.A record producer vs a catalog item will appear nearly the same for your end users, so I'd say it's mostly a process decision in terms of how you'd like to handle them once they're submitted.
5. Record Producer gives a non-itil user the ability to create things like an Incident, Change, basically anything but a Request from a custom front end you deliver via the Service Catalog/Portal.
Please mark as Correct Answer and Helpful, if applicable.
Thank You!
Abhishek Gardade
11 REPLIES 11
hvrdhn88
Giga Patron
The service catalog is a collection of request forms presented as Catalog Items, Record Prodcures, Content Items, Order Guides, etc.
A record producer is a nice front end you can include in your Service Catalog to create records. Ask user friendly questions instead of using field labels on a standard form.
A Catalog Item is a request entry form that utilizes the cart format to associate a parent request to one or more child request items.
https://community.servicenow.com/community?id=community_question&sys_id=219e7665db58dbc01dcaf3231f96...
hvrdhn88
Giga Patron
 A catalog item works with the cart where you can add multiple and then checkout. On the back end it creates a request, request item, and possibly approvals and tasks depending on its workflow.
A record producer is ordered one at a time and creates one record on the back end, most commonly an incident.
AbhishekGardade
Tera Sage
Hello Anand,
Thank You!
Abhishek Gardade
Can we attach a workflow to a record producer?
