‎12-25-2019 08:47 AM
Hi Team,
I would like to understand the dfference between Catalog item and record producer. And advantages,
thanks,
Anand Kumar.
Service Catalog
‎12-25-2019 09:30 AM
Hello Anand,
1. Catalog Item will end up in opening a request and reqeust item and attaches a workflow and catalog task, approvals Where as a Record producer simply insert a record in the selected table.
2. With catalog item, You can add multiple items to cart and generate request and multiple RITM's. where as a record producer it only creates a single record on target table
3. Primarily, the difference is which type of record is created upon submission. I would use a catalog item when you want to generate a request, complete with a workflow, approvals, tasks, etc, and a record producer when you want to gather some information using a form (variables) but create some other type of record (incident, change, enhancement, etc.) as a result.
4.A record producer vs a catalog item will appear nearly the same for your end users, so I'd say it's mostly a process decision in terms of how you'd like to handle them once they're submitted.
5. Record Producer gives a non-itil user the ability to create things like an Incident, Change, basically anything but a Request from a custom front end you deliver via the Service Catalog/Portal.
Please mark as Correct Answer and Helpful, if applicable.
Thank You!
Abhishek Gardade
‎10-04-2022 01:12 AM
Not directly to record producer, but you can trigger flow based on create/update action on the target record (which is submitted from record producer)
‎01-08-2023 11:22 PM
noo we can't attach
‎11-22-2024 10:43 AM
Yes, there is a Workflow pick list near the top of the record producer's configuration screen. (I had to right-click on the form header, choose Configure > Form Layout, and add Workflow.)
‎12-30-2024 06:38 AM
no we cant.
‎10-15-2025 02:51 AM
Yes we can attach a workflow to record producer
