07-05-2025 08:20 AM
I'm new to ServiceNow and currently exploring Change Management. I’d like to understand the differences between Normal, Standard, and Emergency changes.
07-05-2025 08:23 AM
Hi @Richa2712
1. Normal Change:
Definition:A change that follows the full change management process, including risk assessment, approvals, testing, and CAB (Change Advisory Board) review.
Use Case: Scheduled upgrade of a server, deploying a new feature to production.
2. Standard Change
Definition: A pre-approved, low-risk, and frequently repeated change with well-documented steps.
Use Case: Adding a user to a group, rebooting a printer server, or applying a non-impactful patch.
3. Emergency Change
Definition: A change that must be implemented immediately due to an unplanned event like an outage or security breach.
Use Case: Patching a vulnerability under active exploitation, restoring a critical service outage.
Also read this article:
https://www.servicenow.com/docs/bundle/yokohama-it-service-management/page/product/change-management...
If my response solves your query, please marked helpful by selecting Accept as Solution and Helpful.
Prerna
07-05-2025 08:26 AM
Little correction
07-05-2025 08:25 AM
Hi @Richa2712
You can accept multiple answers if you feel that more than one response is helpful and adds value to your question. 🙌
It’s a great way to appreciate the community's efforts and guide others who may have the same query in the future! 😊
