Display inactive users in a Catalog Item (for non-admin users). OOB User query BR
JuanGDev
Mega Expert
Hi everyone,
I’m working on a catalog item where users should be able to request reactivation of inactive users from the same Business Unit as the Requested For.
Here’s the current setup:
  • requested_for → Reference to sys_user
  • business_unit → Single Line Text, auto-populated via Requested For → Department → Business Unit name
  • deactivate_user_ref → Lookup Select Box, used to display inactive users filtered by Business Unit
What I’ve already tried
Lookup Select Box + Script Include
  • Created a client-callable Script Include (GetInactiveUsersByBU) to return inactive users by Business Unit.
  • Added an onChange Client Script on the Business Unit variable to populate the lookup list dynamically.
    ✅ Works perfectly for admin users.
    ❌ When impersonating non-admin users, the list appears blank (only “None”).
Modified the OOB Business Rule “User Query”
  • Tried adjusting the condition to exclude this specific catalog item using:
gs.getSession().isInteractive() &&
!(gs.hasRole("admin") || gs.hasRole("user_admin")) &&
!gs.action.getGlideURI().toString().includes('sysparm_id=###############)
❌ Didn’t work — the inactive users are still hidden.
The challenge:
The root cause is the OOB “User Query” business rule that hides inactive users for interactive sessions unless you’re an admin or user_admin.
If I disable that rule, inactive users appear correctly — but that would have a big side effect, as we’d then need to manually filter out inactive users across other catalog items and references, which isn’t viable long-term.
The question:
What would be the best approach to safely display inactive users to non-admin users in this specific catalog item without disabling or altering the OOB User Query business rule?
JuanGDev
Mega Expert
The variable previously used to select inactive users was changed from a Lookup Select Box to a simple Email field.
  • End-users can now manually enter the email address of the inactive user to be reactivated, instead of selecting them from a restricted reference list.
