Displaying multi row variable set on sc_task
TanviP003244604
Hello Community,
I am trying to display MRVS present on catalog item to sc_task genenrated after approving the RITM.
I am using client script and script include, but not able to show MRVS on sc_task.
Only problem is HTML table is not appearing on sc_task by using jQuery or setValue() using the HTML field.
MRVS is appearing on info message when I am using gs.info() to get table.
Please provide insights on how to solve this problem.Help would be greatly appreciated.
Thank you!
Find attached SScreenshot of gs.info() displaying MRVS:
Please find below client script and script include:
Note : script include is Client callable and Client script is on sc_task (Onload) and  isolated is unckecked
Script include:
var multiRowVariablesSet = Class.create();
multiRowVariablesSet.prototype = Object.extendsObject(global.AbstractAjaxProcessor, {
    getQA: function() {
        //Returns a JSON object representing all the MRVS for a particular requested item along with their values
        var sys_id = this.getParameter('sysparm_sys_id') || '2a175e5edb830090b3da126b3a9619b1';
        var allMRVS = [];
        var ritm = new GlideRecord('sc_req_item');
        gs.info('11');
        if (ritm.get(sys_id)) {
            gs.info('22');
            //loop through the variables looking for multi-row variable sets
            for (var eachVar in ritm.variables) {
                gs.info('33'+eachVar);
                //found one!
                if (ritm.variables[eachVar].isMultiRow()) {
                    gs.info('44');
                    //get Multi-Row Variable Set structure
                    var mrvsDefintion = {},
                        title = '';
                    var mrvsStructure = new GlideRecord('item_option_new');
                    //internal_name added
                    gs.info('55');
                    //mrvsStructure.addEncodedQuery('active=true^variable_setISNOTEMPTY^variable_set.multi_row_variable=' + eachVar);
mrvsStructure.addEncodedQuery('active=true^variable_setISNOTEMPTY^variable_set.internal_name=multi_row_variable');
                    gs.info('66');
                    mrvsStructure.orderBy('order');
                    gs.info('77');
                    mrvsStructure.query();
                    gs.info('88'+mrvsStructure.getRowCount());
                    while (mrvsStructure.next()) {
                        gs.info('w1');
                        //What is the title of this MRVS?
                        if (title == '') title = mrvsStructure.variable_set.title.toString();
                        gs.info('w1');
                        //What about each of the variables
                        mrvsDefintion[mrvsStructure.name.toString()] = {
                            "name": mrvsStructure.name.toString(),
                            "question": mrvsStructure.question_text.toString(),
                            "sys_id": mrvsStructure.sys_id.toString(),
                            "type": mrvsStructure.type.getDisplayValue(),
                            "table": mrvsStructure.type.getDisplayValue() == "Reference" ? mrvsStructure.reference.getValue() : "",
                            "order": mrvsStructure.order.toString(),
                            "row": "",
                            "value": ""
                        gs.info('w2');
                    //get the Multi-Row Variable Set values
                    var mrvsValue = [];
                    var mrvsAnswers = new GlideRecord('sc_multi_row_question_answer');
                    gs.info('w3');
                    //mrvsAnswers.addEncodedQuery('parent_id=' + sys_id + '^variable_set.multi_row_variable=' + eachVar);      mrvsAnswers.addEncodedQuery('variable_set=03aed7ce3388fa10f62ad3382e5c7b65^parent_id=6a9f534233c8fa10f62ad3382e5c7b8a');
                    gs.info('w4');
                    mrvsAnswers.orderBy('row_index');
                    gs.info('w5');
                    mrvsAnswers.query();
                    gs.info('w6'+mrvsAnswers.getRowCount());
                    while (mrvsAnswers.next()) {
                        gs.info('w7');
                        var thisVariable = mrvsAnswers.item_option_new.name.toString();
                        gs.info('w8');
                        if (mrvsDefintion.hasOwnProperty(thisVariable)) {
                            //Get value
                            gs.info('w9');
                            var thisValue = mrvsAnswers.value.toString();
                            gs.info('w10');
                            //if this is a reference field get the display value
                            if (mrvsDefintion[thisVariable].type == 'Reference' && mrvsDefintion[thisVariable].table != '') {
                                gs.info('w11');
                                var getDisplayVal = new GlideRecord(mrvsDefintion[thisVariable].table);
                                gs.info('w12');
                                if (getDisplayVal.get(thisValue)) {
                                    gs.info('w13');
                                    thisValue = getDisplayVal.getDisplayValue();
                                gs.info('w14');
                            //If this is a select box with choices, get the question_choice (display value)
                            gs.info('w15');
                            if (mrvsDefintion[thisVariable].type == 'Select Box') {
                                gs.info('w16');
                                var getQuestionChoice = new GlideRecord('question_choice');
                                getQuestionChoice.addEncodedQuery('question=' + mrvsDefintion[thisVariable].sys_id + '^value=' + thisValue);
                                gs.info('w17');
                                getQuestionChoice.query();
                                gs.info('w18');
                                if (getQuestionChoice.next()) {
                                    gs.info('w19');
                                    thisValue = getQuestionChoice.text.toString();
                            gs.info('w20');
                            mrvsDefintion[thisVariable].value = thisValue;
                            mrvsDefintion[thisVariable].row = mrvsAnswers.row_index.toString();
                            mrvsValue.push(JSON.parse(JSON.stringify(mrvsDefintion[thisVariable]))); //push in a clean object
                    allMRVS.push({
                        "name": title,
                        "details": mrvsValue
        gs.info('return' + JSON.stringify(allMRVS));
        return JSON.stringify(allMRVS);
    type: 'multiRowVariablesSet'
client script :
function onLoad() {
    if(g_form.getValue('request_item')!=''){
        //Check for a multi-row variable set
        var gaMRVS = new GlideAjax('vTil_multiRowVariablesSet');
        gaMRVS.addParam('sysparm_name','getQA');
        gaMRVS.addParam('sysparm_sys_id',g_form.getValue('request_item'));
        gaMRVS.getXMLAnswer(displayResults);
    function displayResults(results){
        var allMRVS = JSON.parse(results), htmlTable = '';
        // var allMRVS = JSON.stringify(results), htmlTable = '';
        // alert("f2"+ JSON.stringify(allMRVS));
        allMRVS.forEach(function(mvrs){
            if(mvrs.details.length !=0){
                //First, sort results by row then by order
                mvrs.details.sort(function(a, b) {if (a.row === b.row) {return a.order > b.order ? 1 : -1;} return a.row > b.row ? 1 : -1;});
                //We'll add our MRVS as a table beneath the description field
                htmlTable+= '<div class="form-group"><div><label class="col-xs-12 col-md-1_5 col-lg-2 control-label"><span aria-label="" data-dynamic-title="" mandatory="false" oclass="" class=" "></span><span title="" class="label-text" data-html="false" data-original-title="" aria-expanded="false">'+mvrs.name+'</span></label></div><div class="col-xs-10 col-md-9 col-lg-8 form-field input_controls"><table style="border-collapse: collapse;border-right:1px solid silver;border-bottom:1px solid silver;width:100%"><tr>';
                //Get the first row number
                var rowNumber = mvrs.details[0].row;
                //get column headers
                mvrs.details.forEach(function(thisEntry){
                    if(thisEntry.row == rowNumber){
                        htmlTable+= '<td style="padding:10px !important;border-left:1px solid silver;border-top:1px solid silver;background-color:WhiteSmoke;">'+thisEntry.question+'</td>';
                rowNumber = '';
                //add each row
                    //insert a new row each time the row number changes
                    if(thisEntry.row != rowNumber) htmlTable+= '</tr><tr>';
                    //add each individual cell value (knowing it has been sorted correctly so they'll all be in order)
                    htmlTable+= '<td style="padding:10px !important;border-left:1px solid silver;border-top:1px solid silver;">'+thisEntry.value+'</td>';
                    rowNumber = thisEntry.row;
                htmlTable+= '</tr></table></div>';
        g_form.addInfoMessage(htmlTable);
        jQuery('#element\\.sc_task\\.project_type').after(htmlTable);
        //g_form.setValue('multi_row_task',htmlTable); //multi_row_task is HTML field
Hi @TanviP003244604 ,
You are using wrong action, the correct action is Create catalog task not Create catalog task record. Looks like it is a customized action.
Anand
9 REPLIES 9
AshishKM
You can add mrvs with SCTASK, similar to other variable, there is no need to write explicit script unless you have to do some other business calculations which are not given in your question.
Please refer the other response from @Ankur Bawiskar and @Anand__99
-Thanks,
AshishKM
Hello @AshishKM , @Ankur Bawiskar , @Anand__99
Thanks for the reply.
I am not getting the template selection option for the create a task action in the flow designer.
As I can see in one community post, their option is present as given in the below screenshot.
My requirement is to display mrvs on catalog task the same as it is visible on RITM.
Could you please guide me.
Thank you !
Thank you !
Anand
@TanviP003244604
you should use "Create Catalog Task" action and why you want to set Template?
