Ebonding Integration by using Flow Designer and REST Message
04-17-2023 09:50 PM - edited 04-17-2023 10:04 PM
Hello All,
We have a requirement in which we have to integrate two ServiceNow Instances by using Ebonding Integration by using Flow Designer and REST Message.
When an Incident is created from the Source instance it should create a Case (CSM) in the Destination instance.
We do not have access to the Source instance and we need to implement this scenario by configuring the configuration on the destination instance. However, we have the connections created on the Source instance.
Appreciate your help.
@Deepak79 @Ankur Bawiskar @umaaggarwal Any thoughts on this would be appreciated. .
Thank you..!!
02-20-2025 10:03 PM
Hope you are doing good.
