Entra Multi Factor Authentication reset using Workflow or Flow
04-03-2025 07:05 AM
Hi Community,
We need to setup from scratch (not aware of anything available using Integration Hub etc.) a process that will reset Entra MFA to allow colleagues to register a new device to handle MFA. Unfortunately, there is no OOB solution like the Okta User Lifecycle (REST) we currently have in place.
I have attempted a Flow/SubFlow/Action and also an attempt using Workflow/MID server script file/Custom Activity.
I have a PowerShell script to handle the reset, I just need to know how/where to place this in ServiceNow to actually work!
Does anyone know of any youtube videos or links to online documentation that I can use to get the solution up and running?
10-19-2026 05:24 AM
hey, did you get this working? I need to achieve the same too.
10-19-2026 02:32 PM
Hello @lmundere
Please check this: https://www.youtube.com/watch?v=MQJyEfF6wTw
10-20-2026 02:27 AM
hi, thanks but this is slightly different on what i want to achieve, i want to reset MFA within Azure AD.
10-20-2026 02:31 AM
The project cancelled the requirement due to security constraints.
