error in flow designer publish
3 weeks ago
I am receiving the following error whenever I try to publish the Flow Designer flow in the DEV instance:
“User does not have access to action instance [sys_id].”
I have already configured the flow to Run As: System User, but I am still receiving the same error while publishing the flow.
Could anyone please help me understand what might be causing this issue and how to resolve it?
Chandan
3 weeks ago
Hi @chandan86patra ,
Could you clarify a few details regarding this flow?
- What exactly does this flow d, and which actions or subflows is it using?
- Is this a brand new flow, or does it already exist in Prod and you are updating it in Dev?
- Do you have the admin or flow admin roles?
3 weeks ago
Hi @chandan86patra,
Why this is happening:
This error is not about the flow’s “Run As” setting. “Run As: System User” only controls the identity used when the flow executes. Publishing is a design-time operation, and it runs under the account of the person clicking Publish. When you publish, Flow Designer validates every action, subflow and step in the flow, and it checks that your logged-in user has permission to read those action instances. If your user cannot access one of them, the publish fails with “User does not have access to action instance [sys_id].”
The usual causes are:
- The action (often a custom action or one from a spoke/application scope) belongs to a different application scope, and your user lacks the role or cross-scope access needed to see it.
- The action instance has a role or ACL restriction (for example, flow_designer / flow_designer_admin or a custom role) that your user doesn’t have.
- The action was imported through an update set or app install and is in a broken or partially migrated state, so the instance record points to something your user can’t reach.
- The action is protected, or the flow was created or last edited by another user and the related records carry restricted access.
How to resolve it
- Look up the sys_id from the error in the sys_hub_action_instance table (or sys_hub_action_instance_v2, depending on your release). Open the record and note which action it references and which application scope it belongs to.
- Check your roles. Make sure your user has flow_designer, and if the flow uses custom or scoped actions, also flow_designer_admin or admin. As a quick test, have an admin publish the flow, or elevate to security_admin and publish yourself.
- Switch to the correct application scope using the scope picker (gear icon, Developer tab) before opening and publishing the flow.
- Review the ACLs and Application Access settings for the action’s scope. Under Restrict Access, confirm that cross-scope read/execute is allowed, or grant access to your user’s role.
- Open the flow and inspect each action and subflow. If one is red, missing or shows an error, remove that step and re-add it. This often clears the stale or broken instance reference.
- If the flow came from an update set, confirm all the dependent records (custom actions, subflows, spoke plugins) were committed and the related plugin is active in DEV.
- Check the System Logs (System Logs > All) around the time of the publish attempt, filtering by the sys_id or “Flow Designer”, for a more specific access message.
“If it still fails, please share your release version, whether the action is custom or OOB, and a screenshot of the error along with the action instance record (the one matching the sys_id from the error)."
Accept the solution if it assisted you with your question & Mark this response as Helpful.
Tarun
3 weeks ago
@Tarun Rekandar it is OOB action "update Record". Version is brazil .
3 weeks ago
Hi @chandan86patra,
Thanks for the details. Since “Update Record” is an OOB action in global scope, a cross-scope restriction on the action itself is unlikely. The problem is probably with that specific action instance inside your flow, or with what it points to. Please try these in order:
- Look up the instance. Open the sys_id from the error in sys_hub_action_instance_v2 and check the Flow/Parent reference. It will confirm which Update Record step in the flow is failing, since the flow may contain several.
- Check the table on that step. Update Record validates your access to the target table at publish time. Confirm that your user has read/write ACL access to that table (and any referenced fields). If the table is in another scope, check Application Access (System Applications > Application Access) for that table’s scope and make sure cross-scope read/write is allowed.
- Delete and re-add the step. Remove the Update Record action, save, add a fresh one, and re-map the Record and Table fields and the data pills. This fixes most “access to action instance [sys_id]” errors caused by a stale or corrupt instance, especially in a flow that was copied, imported via update set, or created by another user.
- Check scope and roles. Make sure you’re in the same application scope as the flow (scope picker) and that you have the flow_designer role. Also check whether the flow was created by a different user, or is in a different scope than the one you’re working in.
- Test as admin. Have an admin publish the flow. If it publishes, the cause is your user’s roles or ACLs. If it still fails, the instance record itself is broken (step 3).
- Rule out cache and sessions. Run cache.do, log out and in again, and retry in an incognito window.
- Check the logs. Look at System Logs > All, filtering for the sys_id or “Flow Designer” around the publish time. There is often a more specific ACL or table message.
If it still fails, please share the screenshot of the action instance record, the flow’s application scope, and the roles on your user. Also, if the flow came over in an update set, check whether the Update Record action type (sys_hub_action_type_definition) was customized or skipped.
Hope this helps, Accept the solution if it assisted you with your question & Mark this response as Helpful.
Tarun
2 weeks ago
I ran into the same error when changing Run As to System User on a flow ("User does not have access to Action instance"). In my case the cause was that the subflows were still set to Run As "User who initiates session" while the parent flow was set to System User. Once I changed the subflows to System User first, the parent flow saved without any problem. If your flow calls nested subflows, start from the bottom of the chain and work up.
