Error Messagejava.sql.BatchUpdateException: (conn=284652) Duplicate entry 'incident-assignment_group
Nitish16
what I am trying is in Incident table which is the child table of Task table, in assignment_group column trying to Override reference qualifier and adding the active=true^EQ
so that assignment_group  will reflect only active groups and that change should happen in the Incident table only which is child table, but it is throwing error as above
2 ACCEPTED SOLUTIONS
Brad Bowman
Mega Patron
What does your new reference qualifier look like?
To clarify, are you changing this on the dictionary entry - so on the task table:
Or on a new or existing dictionary override for the incident table?
@Nitish16 Yep, that's correct. You can't have more than one Dictionary Override for the same table and field. I wish I could mark your message as the correct answer.
Nitish16
This problem was solved by understanding the Dictionary Override functionality. There was already an entry for the Incident table with an existing override condition (which I didn't fully understand and didn't remove). When I tried to add another override for the Incident table with a new condition (active=true^EQ), it caused a duplicate entry error. To fix this, I located the pre-existing Incident table entry in the Dictionary Override and simply added my new condition (active=true^EQ) to the existing one, leaving the original condition as it was. This resolved the issue."
Easy Summary:
Basically, the system was saying, "You already told me how to handle the 'assignment group' field in Incidents once, you can't tell me again in a separate rule!" So, instead of trying to create a whole new rule, I found the old rule and just added my new instruction to it. Now it works!
Thank you Robert for your time
