ESC Portal
PoojaD900590353
ESC Portal - My Tasks Page
In the ESC Portal, when the Reject button is clicked, the input field appears as a single-line text box. I want it to be a multi-line textarea. I tried using DOM manipulation in the sn_ex_sp_action_type client script, but it isn't a reliable solution for future updates. Let me know if there's a proper solution for this.
@PoojaD900590353
I shared the analysis below, please enhance your script further.
it comes from combination of these 2 widgets -> todo-approval-actions and todo-approval
the todo-approval widget calls todo-approval-actions widget
@PoojaD900590353
Ankur Bawiskar
@PoojaD900590353
what's the max length of that single line?
User just need to enter rejection reason, why would they type in long sentences.
I will recommend staying to OOTB and not to clone etc.
check this
Service Portal widget with Modal window issue
