πŸš€ Exploring ServiceNow Flow Designer: Best Practices & Insights
JosafKollur
Hi ServiceNow Community!
I wanted to open a discussion and share some thoughts on Flow Designer, and also learn from your experiences.
As we all know, Flow Designer is an incredibly powerful tool for automating processes without writing code, and it’s been a game changer for building maintainable, scalable workflows in ServiceNow.
 What I love about Flow Designer:
  • Low-code, intuitive interface: Great for both technical and non-technical users.
  • Reusability with subflows: Helps keep flows modular and easier to maintain.
  • Rich integration capabilities: With spokes and integration actions, connecting to external systems is so much simpler.
  • Testing and debugging: The built-in testing capabilities really help reduce back-and-forth.
 A few best practices I’ve been following:
  • Always define clear naming conventions for flows, subflows, and actions to make them easily identifiable.
  • Use subflows wherever possible to avoid duplication and improve reusability.
  • Keep actions small and focused to improve readability and maintenance.
  • Document each flow properly β€” including triggers, conditions, and expected outcomes β€” so that future developers (or even yourself!) can quickly understand the logic.
  • Use data streams wisely to handle large data sets efficiently.
 I'd love to hear from the community:
  • What tips and tricks do you use to optimize Flow Designer?
  • How do you handle error handling and rollback scenarios in complex flows?
  • Any specific design patterns or real-world use cases you'd like to share?
Looking forward to learning from all your experiences! Let's make Flow Designer workflows even more robust and user-friendly together.
Thanks in advance for sharing!
4 ACCEPTED SOLUTIONS
Rafael Batistot
Mega Patron
Hi @JosafKollur
I’m not a big fan of flow designer it’s because in my daily routine I use to create incident via inbound email
Why I’m not a fan? In this specific process is possible to add a condition by subject like
Subject contains / start with…
in this specific case you need add many key words to trigger the flow
Ex.  the subject is : My Report
If the user send my report the trigger doesn’t work and you need to add other condition
for this specific case, to work, you need to create many conditions with the same phase:
My Report
my report
my reports
my Report
My report
Imagine if you need to create many flow with different phases?
To complete my point, that I’m not a fan,
the flow designer is only table that is not possible create trigger and flow via script, different than workflow
Anyway I hope some engineers from ServiceNow see my post and fix it
If this response was helpful, please mark it as Helpful and, if applicable, as Correct.
This helps other users find accurate and useful information more easily
Andrew_Johnson
Hello @JosafKollur
 I prefer Flow Designer for its performance and ease of use, and I’ve recently started incorporating Decision Tables to reduce branching and improve reusability.
I am currently automating Change Task dependencies. The requirement is to allow users to dictate dependencies based on Task Type and Order.
In this logic:
Task Type acts as the primary filter.
Order determines execution sequence: Tasks with the same Order value run in parallel, while the Flow progresses through different Order values in ascending sequence.
To manage this:
I’m using an After Business Rule on change_task to trigger a Subflow when the State or Order changes.
I also need a Before Business Rule to act as a validation layer. Since Flow Designer doesn’t provide "pre-save" governance, this BR will prevent users from saving records that don't meet specific dependency criteria.
JennyBell
Hi Everyone!  Looking to get some best practices for flow designer.  Many times I am modifying a current flow to fit a new situation.  What is the best practice when you change the main approval process in an existing flow?  Do you copy the existing flow and use that in production or do you modify the existing flow and overwrite/delete the original?
Thanks!
Hi @JennyBell
it’s depends of scenario… if the approval logic changes significantly, create a new flow and keep the existing one intact.
If the change is minor,
modify the existing flow.
For shared logic, use a Subflow to avoid duplication.
Andrew_Johnson
Hello @JosafKollur
In this logic:
To manage this:
JennyBell
Thanks!
Hi @JennyBell
