Flow Designer and Catalog Tasks
davidsmith
I am using Flow Designer to create catalog tasks for a particular item. In the days of Workflow Studio, you could populate the catalog tasks with the relevant variables so the task's fulfiller could see the task's details. Please see the image below.
flow.pngIs it possible to do this with flow designer? The only way I can do this is to populate the description of the task with the relevant details.
David
Zach Koch
Yes, in flow designer, when you have a Create Catalog Task step, there is a section under it called Template Catalog Item. You would configure it to choose the item you want variables from, then it will give you a slushbucket of variables to include on the catalog task when it gets generated. It would look like this
Zach Koch
davidsmith
Dear Zach,
Many thanks for this it now works perfectly.
Kind regards
David
