Flow designer approvers called from decision table not triggering
08-05-2026 12:56 AM - edited 08-05-2026 01:05 AM
I have configured decision table having requestor's organization stored in combination with organization's approver. When I call this decision and pass input as Requested For (from Get catalog variable) the approval is not getting triggered. However, when a "Test" the flow from flow designer interface, the approval gets triggered. What am I missing ?
08-05-2026 04:17 AM
Hi @Shraddha17
Could you please share "Get Catalog Variables from M365 Copilot Cowork Variable Set" Action details.
Also , if your are getting flow context for your flow, please check what input value - you are getting for the mentioned Action.
08-05-2026 04:57 AM
It is fetching the correct values. PFA snippet
08-05-2026 02:02 AM
Hello @Shraddha17 ,
share the screenshot from flow executions both when normal triggering and testing..
08-05-2026 03:02 AM
did you confirm if during flow execution the correct user sysId is passed as input to decision table?
share that screenshots
08-05-2026 04:08 AM
Yes Ankur,
Input is being passed correctly, also decision table is returning correct answer
