Flow Designer Error – “The requested flow operation was prohibited by security rules” reoccurring
Hrithikah
Hi Team,
I’m facing an issue in Flow Designer related to the error:
“The requested flow operation was prohibited by security rules.”
Background:
  • We have a requirement to create requests via inbound email, and this setup is currently working.
  • Earlier, when users with snc_internal role attempted to create requests through email, the flow failed with the same security error.
Initial Fix Implemented:
To resolve it, we made the following changes:
  • Set the flow to Run As: User who initiates the session
  • Added catalog_admin role in the “Run with roles” property of the flow (gave role to flow itself)
After this:
All users were able to successfully raise requests via email
Current Issue:
  • The same error has started occurring again:
  • The flow is now intermittently failing / breaking even with the above configuration in place
  • Create record actions are working, but update record actions are failing within the flow
  • Also, when System User is selected under Run As, the “Run with roles” option is not visible, limiting our ability to control execution roles
Any insights or suggestions would be greatly appreciated. If anyone has encountered a similar issue or has recommendations, please share.
Ankur Bawiskar
@Hrithikah
screenshots please
My thoughts
-> Mark Flow as Run as - System User
check this KB
Resolve flow failures caused by security rules for the system user
Hrithikah
 @Ankur Bawiskar , @Tanushree Maiti , @1__PrabakaranC
Thank you all for your inputs.
I have added "Itil" role in the “Run with roles” property of the flow It is working but yes I will try changing the run ast to system user as well.
Thanks again for the suggestions.
