Flow Designer permissions issue
06-25-2025 05:12 AM
Hi, I'm having some flows, which at some point will try and generate some catalog tasks, if some verification fails, namely, if a record field is empty, whatever, doesn't matter.
The flow runs as a System User, yet when the catalog task step is reached, I'm getting this error:
[The requested flow operation was prohibited by security rules.]
I don't understand what is causing this behavior.
Thank you for your help
06-25-2025 05:34 AM
Ideally with system user it should not give security issue.
Is this happening all the time or intermittently?
06-25-2025 05:46 AM
It is happening all the time unfortunately : (
06-25-2025 05:56 AM
did you check any ACL is blocking the insertion of catalog task since you are unable to create task?
share flow screenshots.
