Flow designer- How to change the existing flow to run as system user.
DiNesh77
Hi all,
I would like to know how to make existing flow in flow designer to run as system user as the catalogue items are causing some problem while running as "user who initiates session".
Any idea how to change ?
Ivan Betev
Hello DiNesh,
Go to Application Navigator => Flow Designer => Designer:
1. Open an existing flow;
2. Select Properties and change the Run As user.
Useful links:
Setting Run As.
Is that it?
Have a nice day! 🙂
Run As does not show for existing flow
swathisarang98
Hi @DiNesh77 ,
Open your existing Flow, click on ... dots as shown below,
Click on properties
Update the Run as
If the above doesn't work please let me know or share some screenshot.
Please mark this comment as Correct Answer/Helpful if it helped you.
Swathi Sarang
harikrishna De1
I am not able to see run as field in properties
