10-11-2021 10:21 PM
I have created flow designer for one catalog item and using subflow in that .
I am passing trigger requested item as input in subflow.
How to use those input variables in catalog task description script. I want to use RITM's sys_id in subflow script.
can someone please help.
Sonali j
Service Catalog
10-12-2021 01:30 AM
So can you share a bit of what you are scripting? Anyway, without knowing that, you do have a subflow input "ritm", you can access that in script using:
var ritm_sysid = fd_data.subflow_inputs.ritm
Kind regards,
Mark
2020, 2021 ServiceNow Community MVP
2020, 2021 ServiceNow Developer MVP
10-11-2021 10:41 PM
Hi there,
Can you clarify your question? What is your understanding of "subflow script".
Kind regards,
Mark
10-11-2021 11:25 PM
Hi Mark,
I have created flow designer for catalog item and in that flow designer I am using subflow.
Subflow contains some set of catalog tasks , and for that catalog tasks description I need sysid of parent RITM .
subflow in flow designer:-
subflow inputs:-
Sonali J
10-11-2021 11:31 PM
Can you use below instead in your Flow? That would provide you with the sys_id of the newly generated Requested Item (= tested). And obviously, you could use that as input for your subflow.
Kind regards,
Mark
10-12-2021 12:12 AM
