Flow Designer maximum actions and performance
ShAn21
I have couple of questions regarding flow designer after reading the following in a snow article "By default, flows can have no more than 50 actions. To change the default behavior, increase the value of the sn_flow_designer.max_actions system property. However, consider the performance impact that a large flow may have on your instance.."
I have a huge flow with 130 actions and yes its crazy slow in the UI but runs fine.
So I spoke to our architects and they were not really happy about increasing the min count. So I have decided to split the flow designer into 3 based on a field type. 3 types of requests add, extend and remove. There were lot of ifs and else coz of this. Number reduced easily under 50 for remove type but for add/extension it was still over 50. So I decided to create couple of subflows which was common for both and total actions are clearly below the mark now. I have a subflow which calls another subflow as well.
So my question is
1) Was my approach good to split the flows based on conditions? and also use subflows?
2) Does subflows show better performance then putting everything in one flow (UI works like charm now. ;)) or was my approach just a trick to get under max count 😞
Using subflows is a great practice - it allows you to potentially reuse some actions in the longer term. It's a bit like when you're coding, try and make a flow do as little as possible, and break out into subflows that do as little as possible - it increases the reusability of your subflows.
Hi Mike
Performance wise does subflow add any value?
For example having 80 entries in a single flow and having 40 entries in the main flow with remaining entries in a sublow which is also reusable. For sure there is no lag in FD UI which takes minutes.
Thanks.
Yeah it does help with the UI performance by keeping the number of entries in the flow lower by using subflows.
There's no performance value-add platform wise by using stuff in subflows.
Travis Rogers
I know this thread is old, but just want to remind anybody who stumbles across this of one important thing: Decision Tables are your friend 🙂 You can consolidate much of that if/else logic into a decision table to allow your flow to focus on the execution itself. This helps with the total flow actions, and it also helps with flow maintenance and legibility.
This video is a great intro to decision builder. You'll want to watch at least timecode 2:30-11:00 for a feature introduction and possibly 28:00+ for the demo. The rest of the video is great too, if you have the time.
The two second pitch for Decision Tables is:
Go from a flow with a ton of logic that looks like this:
To an easy to maintain logic table that looks like this:
So your flow can be simplified to look like this:
-Travis
