Flow Designer ( Multi Level approval )
07-08-2022 09:56 AM
Hi Team,
Need your help here !...
I have a requirement for multi level approval ( conditionally) --- Single level approval Conditionally.
Ex : Once a submit a catalog item request & if condition satisfied then first approval triggered to 'X' group then if it approves then go for approval for next 'Y' group.
But if condition is not satisfied then first level approval will not triggered to 'X' group , it will directly go for next 'Y' group approval.
Issue :. There are 112 steps already been configured in my flow Designer ( as there are multiple SCtasks to be generated here in our requirement ), now unfortunately it is limiting me to add another steps/actions.
I just a suggestion for Ask for Approval script ( to reduce my flow steps ) that will suffice above both Multi Level approval and single level approval ( Like X n Y ) or only Y.
I would appreciate if any help offers in this regards...
Akshay
Service Catalog
07-08-2022 10:01 AM
Hi Ashkay,
In order to reduce the flow steps, I would propose to move some flow steps to a subflow and than call this subflow from the main flow.
Best Regards,
Marcin
If my answer helped you in any way, please mark this answer as helpful and correct.
10-18-2022 05:33 PM
Hi Akshay- Did you get a way to do it ? if yes could you share solution ??
Also how did you designed multi approval in your flow ?
