flow designer script
I am getting two or more sysid via flow varible in the flow designer,  I neded to pass one by one sysid in the another subflow flow along with group name , but it takeing only first sysid other sysid is not taking .I have designed using the for each records , can anyone advise me how to achive this requirement.
if the  receive  5 sysid is than 5 times subflow should run can anyone advise me how to do it .
Thanks and Regards,
Chandan Patra
Sandeep Rajput
@Community Alums Are you sure the for each is not calling the subflow with other sys_ids. Usually, the flow context only shows the first loop iteration and you need to change the number associated with the loop to see the next iteration.
