Flow designer send Email
LT_23
Hello I have the follwoing flow and I want to include an email that will be sent to the manager so that they know when their employees open a request.My question is where should I add this action and should I use the Send Email over the notification or else.
Thank you in advance
2 ACCEPTED SOLUTIONS
Aditya_hublikar
Hello @LT_23 ,
You can use Send email action which is more relative for you requirnment . If you use send Notification action then you need to create email notification first and then you can use that notification in send notification action . You can use send email action at starting of flow action if you want to simply send details about when their employees open that request .
If this helps you then mark it as helpful and accept as solution.
Aditya
Hello @LT_23 ,
I hope you are doing well . Does my response helps you ? If yes then mark it as helpful and accept as solution it will helps future queries.
Aditya
LT_23
Thank you all your contribution is very much appreciated
