Flow engine context is in queued state and not executing
srijamadhuri
Flow engine context for the flow is in queued state and not executed.
If we go to flow designer and test - flow is triggered.
Is there any configuration where flow designer triggering to be enabled?
We used catalog item through record producer  - on create triggering the flow.
Attached the screenshot where you can see 2 flows are queued which came for service portal catalog form submission and other one which is in complete state from flow designer test .
 Anything over upgrade to verify?
15 REPLIES 15
this is bit odd, can you try to add test flow designer which will have only first action and after add log , then test it while creating a request.
i would say give a try by changing the flow action for troubleshoot.
Priyanka Chandr
Mega Guru
Please have a look into this
https://hi.service-now.com/kb_view.do?sysparm_article=KB0722358
that will help you.
Please mark it correct and helpful, if applicable.
srijamadhuri
Hi @Priyanka Patil ,
Verified, They are in ready state
shivanki1
Mega Expert
Hi srijamadhuri,
I am having same issue ! Did you get the solution of this.
Clyde Wimbrough
Giga Contributor
I'm having same issue after upgrade to Orlando.  Has there been a solution found for this issue.
