Flow engine context is in queued state and not executing
srijamadhuri
Flow engine context for the flow is in queued state and not executed.
If we go to flow designer and test - flow is triggered.
Is there any configuration where flow designer triggering to be enabled?
We used catalog item through record producer  - on create triggering the flow.
Attached the screenshot where you can see 2 flows are queued which came for service portal catalog form submission and other one which is in complete state from flow designer test .
 Anything over upgrade to verify?
15 REPLIES 15
Atulit
I am facing the same issue in Paris release. Has there been a solution for this issue.
elle
I'm facing the same issue in Quebec release, how did you fix it?
Hi LP,
What you see in below?
Thank you
Prasad
They are all in ready state, but not processed.
Atulit
One workaround for this is you can increase the timeout of the flow.
Usually, this happens if the flow is large and it takes a long time to load the flow in memory.
If you calling the flow/subflow from a scripted REST API then you can increase the time out as shown below.
var result = sn_fd.FlowAPI.getRunner().subflow('<subflow_name>').inForeground().withInputs(inputs).timeout(<time in ms>).run();
Also, another way is to use functions given by Flow API like ScriptableFlowRunner - quick() which runs the flow quickly without creating execution details or other related records.
More details related to Flow API could be found here: https://docs.servicenow.com/bundle/quebec-application-development/page/app-store/dev_portal/API_refe...
