Difference between After vs Async Business Rules in ServiceNow: The Complete Guide
Aditya_hublikar
If you're working with ServiceNow Business Rules, you've probably encountered both After Business Rules and Async Business Rules. They might seem similar since both execute after a record is saved, but they work very differently under the hood.
Understanding these differences is crucial for building efficient workflows and avoiding common pitfalls—especially when dealing with notifications.
Let's break it down.
1. Execution Style: Synchronous vs Asynchronous
After Business Rule → Runs Synchronously
  • Waits for the previous step to complete before moving to the next
  • Executes step-by-step in sequence
  • The user must wait until all operations finish
Async Business Rule → Runs Asynchronously
  • Does NOT wait for the previous task to complete
  • Runs in the background
  • The user gets an immediate response while tasks continue processing
2. Transaction Handling: Same vs Separate
What is a Transaction?
A transaction is a set of actions executed together and treated as one single operation. If one part fails, the entire transaction can be rolled back.
After Business Rule → Uses the Same Transaction
  • All steps are part of one transaction
  • Each step depends on the previous one completing successfully
  • Ensures strict order and data integrity
Async Business Rule → Uses a Separate Transaction
  • Runs in a separate background transaction (queued)
  • Independent from the main transaction
  • Doesn't block the user interface
3. Real-World Examples
Example 1: After Business Rule
Use Case: After saving a parent task, a child task should get updated.
Since After BR runs synchronously in the same transaction, it ensures the child task update happens immediately and in the correct order.
Example 2: Sending Notifications
Use Case: Send a notification after a record is saved.
Here's where things get interesting. Let's say you're working with a Problem record and need to:
Steps:
  1. Create Problem
  2. Create Problem Task
  3. Create relationship (link Problem and Problem Task)
  4. Send Notification
4. Why After BR Can Cause Issues with Notifications
With After Business Rule (Same Transaction):
Since After BR uses the same transaction, the execution flow looks like this:
i.   Create Problem
↓ (wait...)
ii. Create Problem Task
↓ (wait...)
iii. Create Relationship (link Problem and Problem Task)
↓ (wait...)
iv. Send Notification
The Problem:
Until step iii (creating the relationship) is fully executed and completed, step iv (send notification) will NOT execute.
Why This Matters:
  • If step iii takes time or encounters an error, the notification gets delayed or may not send at all
  • Users experience slower response times
  • The entire transaction is blocked until every step completes
This is why After BR is NOT recommended for sending emails or notifications.
5. Why Async BR Is Perfect for Notifications
With Async Business Rule (Separate Transaction):
Async BR uses a separate transaction that runs in the background queue. Here's how it works:
i.   Create Problem
iii. Create Relationship (executes in background)
iv. Send Notification (starts immediately, doesn't wait for step iii)
The Advantage:
  • Step iii executes in the background
  • Step iv (notification) starts executing immediately
  • User doesn't experience any delay
  • Notification is sent without waiting for the relationship creation
Quick Comparison Table
Aspect After BR Async BR
ExecutionSynchronous (waits)Asynchronous (background)
TransactionSame transactionSeparate transaction
SpeedSlowerFaster
DependencySequential (one after another)Independent
Best For- Updating child records
- Data validation
- Field calculations
- Sending notifications
- API calls
- Heavy background tasks
When to Use Each Type
Use After Business Rule When:
  • You need strict sequential execution
  • Child records must be updated immediately after parent
  • Data integrity is critical
  • Operations depend on each other
Use Async Business Rule When:
  • Sending emails or notifications
  • Making API calls
  • Running heavy background processes
  • User response time is important
  • Operations can run independently
Key Takeaway
For notifications and emails → Always use Async Business Rules
Why? Because Async BR:
  • Uses a separate transaction
  • Doesn't wait for previous steps
  • Ensures fast and reliable notification delivery
  • Provides better user experience
0 REPLIES 0
