Flow engine context is in queued state and not executing
srijamadhuri
Flow engine context for the flow is in queued state and not executed.
If we go to flow designer and test - flow is triggered.
Is there any configuration where flow designer triggering to be enabled?
We used catalog item through record producer  - on create triggering the flow.
Attached the screenshot where you can see 2 flows are queued which came for service portal catalog form submission and other one which is in complete state from flow designer test .
 Anything over upgrade to verify?
15 REPLIES 15
elle
How can I create a Flow API?
