Flow need to wait everymonth on particluar date
08-12-2026 03:04 AM
Hi All
There is scenario where after flow is triggered, flow should wait untill 25th of everymonth, How we can achieve this in flow designer?
Could someone provide response on this?Thanks in advance
Nandini
08-12-2026 05:47 AM
why not trigger that flow directly on 25th of every month rather than making it trigger and wait till 25th?
If you are on Australia then this is possible directly, check docs
If not on Australia then do this
1) create subflow to have your logic and copy the code snippet
2) then run scheduled job month and then call subflow from your scheduled job script
08-12-2026 07:45 PM
Just following up to see whether my suggested solution worked for you.
If you're still facing any issues, I'd be happy to help further.
