g_scratchpad not defined : error coming onSubmit catalog client script
app
Mega Expert
Hello All,
I have written one catalog client script using g_scratchpad.
It is working on portal but on the backend side form.
Please let me know how can this be solved.
Script:
function onSubmit() {
var actionname = g_form.getActionName();
if (g_scratchpad.isSupportGroup) {
return true;
var val = g_form.getDisplayValue('datacity_service');
var ga = new GlideAjax("DataCityRequest");
ga.addParam("sysparm_name", "populateApplicationFields");
ga.getXML(populateApplicationFields);
return false;
function populateApplicationFields(response) {
var obj = JSON.parse(answer);
var PV_Corporate_Request = obj.property1.split(",");
var PV_Customer_Request = obj.property2.split(",");
var PV_Operations_Request = obj.property3.split(",");
var AppropriateCategory = g_form.getValue('appropriate_category');
if ((AppropriateCategory == 'Request Enhancement') || (AppropriateCategory == 'SME-Project Estimates') || (AppropriateCategory == 'Report Defect')) {
if (PV_Corporate_Request.indexOf(val) > -1) {
g_form.setValue('support_group', 'DWBI-Corporate-Requests');
g_scratchpad.isSupportGroup = true;
} else if (PV_Customer_Request.indexOf(val) > -1) {
g_form.setValue('support_group', 'DWBI-Customer-Requests');
} else if (PV_Operations_Request.indexOf(val) > -1) {
g_form.setValue('support_group', 'DWBI-Operations-Requests');
g_form.setValue('support_group', 'ITDS-BI-REQUESTS');
g_form.submit(actionname);
script Include:
var DataCityRequest = Class.create();
DataCityRequest.prototype = Object.extendsObject(AbstractAjaxProcessor, {
populateApplicationFields: function() {
var obj = {};
obj.property1 = gs.getProperty("Datacity Request - DWBI-Corporate-Requests");
obj.property2 = gs.getProperty("Datacity Request - DWBI-Customer-Requests");
obj.property3 = gs.getProperty("Datacity Request - DWBI-Operations-Requests");
return JSON.stringify(obj);
type: 'DataCityRequest'
-O-
Actually, to make it as "safe" as possible, you may want to try a different approach: use g_scratchpad where available, else use NOW:
function onSubmit () {
	var scratchpad = g_scratchpad || NOW;
	if (scratchpad.u_isSupportGroup) {
		return true;
	return false;
	function populateApplicationFields (response) {
				scratchpad.u_isSupportGroup = true;
			else {
		else {
22 REPLIES 22
-O-
Can you post back the Script as tested by you?
app
Mega Expert
It is setting 'ITDS-BI-REQUESTS' for everything.
script:
var scratchpad = typeof g_scratchpad == 'undefined' ? NOW : g_scratchpad;
return true;
return false;
else {
g_form.orderNow(actionname);
else {
-O-
OK, but that is most likely due to some different cause. Can you add extra line
		alert('[' + val + ']\n[' + AppropriateCategory + ']');
after line
do a test and let us know what is prompts?
app
Mega Expert
This came.
-O-
It seems g_form.getDisplayValue() is another thing that exists only in Portal. You need to switch to values and use
var val = g_form.getValue('datacity_service');
Alternatively you could "send in" val (obtained calling getValue) as a GlideAjax parameter, get its display value on server side (in the Script Include) and send it back alongside property1, property2 and property3.
