Get Multi-Row Field Code
Snow Tomcal
I want to custom the multi-row variable set for my instance. Is there a way to get the it's code?
Thanks 🙂
Mark Roethof
Hi there,
Can you clarify what you actually mean with "it's code"?
Kind regards,
Mark Roethof
10x ServiceNow MVP
LinkedIn
The Client and Server code (To create the same functionality).
Hmmm oke. I don't think anyone here will be able to help you on that 🙂 So you would need to do that completely yourself without having input of existing code.
Do wonder though, why build your own mechanism. What was the reason you started something custom like you mentioned in the other replies.
Kind regards,
Mark Roethof
10x ServiceNow MVP
LinkedIn
