get yes/no in client script confirmation prompt
anur
Have a client script, which on a clearing a field value , will give below confirm dialog
Is there anyway to get "yes" and "no" instaed of "ok" and "cancel"
Jon Hogland
How do I view other replies?
Naveed_Hussain
Hi Anur,
The following code will help you to clear fields values by using confirm box / pop up box. When you'll click on 'Ok'. Your required fields values will clear. If you'll click 'Cancel' nothing will happen.
please mark my answer as accepted solution and helpful, if it works for you.
Thank you!
function onLoad() {
    var answer = confirm('Are you sure for clear field values');
    if (answer == true) {
        // I have selected dummy fields but you can select as per your needs
        g_form.setValue('number', '');
        g_form.setValue('short_description', '');
        g_form.setValue('description', '');
        return false;
